My car has the front and rear A/C system. The compressor, condenser, dryer, and orifice tube have been replaced. When attempting to charge the system after evacuation and gauge purging, the system only took about half (30 oz. of the recommended 60 oz.) of the refrigerant and the pressure readings seem high. 95 degree ambient temperature at idle with A/C on Max; Low-65 High-260. Also, the compressor is constantly engaged and does not cycle. I believe the issue to be either a blockage somewhere, air that found its way into the system during charging, and a problem with the rear expansion valve. I would appreciate your thoughts on this situation.
Thank You
Thank You
Sep 17, 2019 at 2:54 AM
