A/C compressor engages when A/C is not on
226,000 MILES • 5.7L • V8 • AUTOMATIC
GLEUER1930
While trying to sort out why I have no heat I have discovered the A/C compressor is coming on and I do not have the in cab controls on A/C. Is it possible the A/C compressor engaging and not having heat are related? Could it be the control panel?
Jan 11, 2019 at 6:29 AM
STEVE W.
  • 15,418 POSTS
Do you notice the A/C running when in defrost? Or is it in every mode? If while in defrost mode, it is normal. The system runs in defrost to dry out the air in an attempt to keep the windows from fogging inside. If it is running in other modes as well then you have a problem. It may be related to having no heat if the controller thinks it is always set to A/C. That would tend to run cold air through the heater core. Do you hear any change in airflow when you switch from hot to cold and back?
Jan 11, 2019 at 10:03 AM
GLEUER1930
The AC is on only in defrost, I never realized that was normal.
I haven't really listened for a change in air flow, I'll do that next. I also need to check the actuator. The water line from the block is hot but the return to the radiator is cool, thinking the core may be blocked.
Thanks
Jan 11, 2019 at 10:49 AM
STEVE W.
  • 15,418 POSTS
Yeah, that was sort of snuck in there because they changed the way the systems worked because of the venting systems changing over time.
If the in line is hot and the out isn't it is most likely the core is plugged. You can try to reverse flush it using a garden hose or a flush gun. 50/50 as to it working as it depends on what is plugging the core.
Lot's of videos out there on flushing. However, if the core is failing unplugging it could lead to leaks.
Jan 11, 2019 at 11:37 AM
GLEUER1930
Thanks Steve. I figure it's best to put in a new heater core, the truck is twenty five years old now and it's in great shape.
I appreciate the help.
Jan 11, 2019 at 11:57 AM
STEVE W.
  • 15,418 POSTS
If you're going in for the core, replace both the heater and AC cores and do the upgrades for the doors and actuators while you're in there. There are also a few spots that you can add sound deadener pads to prevent any dash squeaks. The service information we have shows how to change them out but a video is a lot better.
Jan 11, 2019 at 3:26 PM
