1970 Jeep CJ5 Ignition issues
CJ MEDEVAC
  • 11,005 POSTS
ON THAT LAST TEST
MAKE SURE YOU DISCONNECT THE WIRE(S) THAT CONNECT TO MR. DISTRIBUTOR SO THAT THERE IS NO "OUTSIDE" INTERFERENCE WITH THE TEST
THE MEDIC
Wednesday, December 10th, 2014 AT 5:02 PM
SCHULTZ2659
  • 18 POSTS
With no wires connected the test is good.
As for the voltage on the resistor I switched the wires and the voltage is now correct.
Wednesday, December 10th, 2014 AT 5:06 PM
CJ MEDEVAC
  • 11,005 POSTS
12 OR SO ON THE KEY SIDE?
6-9 OR SO ON THE COIL SIDE?
THE MEDIC
Wednesday, December 10th, 2014 AT 5:12 PM
SCHULTZ2659
  • 18 POSTS
It's just short of six on the coil side and 12 on the key side.
Wednesday, December 10th, 2014 AT 6:40 PM
CJ MEDEVAC
  • 11,005 POSTS
HOW COME I AIN'T HEARD HIM BUST OFF YET?
THE MEDIC
Wednesday, December 10th, 2014 AT 6:46 PM
SCHULTZ2659
  • 18 POSTS
Because it still has no spark. Makes no sense.
Wednesday, December 10th, 2014 AT 6:50 PM
SCHULTZ2659
  • 18 POSTS
I still gotta check the rotor in the cap but I took a break. Too frustrated right now. I got the Pertronix coming in tomorrow. I also have hunters coming in so I may not have a chance to work on it till Sunday or Monday.
Wednesday, December 10th, 2014 AT 6:52 PM
CJ MEDEVAC
  • 11,005 POSTS
CAP OFF - ROTOR TURNS WHEN CRANKED?
COIL IS ONE THAT USES "EXTERNAL RESISTOR"
WHERE'D YOU GET IT/ PART NUMBER?
YOU ARE 100% POSITIVELY SURE YOU DROPPED THE DISTRIBUTOR IN AT TDC, AND ROTOR WAS POINTING AT #1 SPARK PLUG WIRE? (I'LL GO OVER THIS IF NEED-BE)
TRIED 1960s "GRAND THEFT AUTO" YET?
UNHOOK THE WIRES ON THE POS SIDE OF COIL--- THEN, POS BATTERY TO POS COIL- NO RESISTOR (JUST FOR THIS TEST) SEE MY PRETTY PICS
'NUTHER HOUR, HURRY BACK!
THE MEDIC
Wednesday, December 10th, 2014 AT 7:02 PM
CJ MEDEVAC
  • 11,005 POSTS
THE COIL PIC WAS MADE FOR A '79-'86 CJ-5/7
THEY HAVE RESISTANCE WIRES, NOT A BALLAST RESISTOR
HOWEVER- WIRE OR BALLAST, IT IS STILL "EXTERNAL RESISTANCE" PRIOR TO REACHING THE COIL
I HAD TO USE A BALLAST RESISTOR ON MY '77 CJ-5 BECAUSE I UPGRADED THE PRESTOLITE (CRAPPY IGN SYSTEM) TO A "MOTORCRAFT" IGN, JUST LIKE '79-'86
'76-'78 USED A COIL WITH INTERNAL RESISTANCE
INSTEAD OF USING HALF/ HALF OF EACH SYSTEM, I OPTED TO DO IT ALL LIKE '79 ('CEPT FOR THE ADDITION OF THE BALLAST RESISTOR - A MUST HAVE FOR MY MODIFICATION) THIS KEEPS ME USING/ SAYING IT'S A '79 FOR MY INFO AT A PARTS STORE, THIS CUTS DOWN ON CONFUSION WHEN I GET IGN STUFF!
THE MEDIC
Wednesday, December 10th, 2014 AT 7:15 PM
CJ MEDEVAC
  • 11,005 POSTS
POINTS ARE SET CORRECTLY?
HAVE YOU MOVED THE DISTRIBUTOR CW AND CCW WHILE LOOKING FOR SPARK? (MAYBE THE POINTS ARE OPENING BETWEEN TOWERS)
THE 1960s GRAND THEFT AUTO TEST MIGHT GIVE US AN IDEA ON THE COIL HAVING/ NEEDING RESISTANCE
IF YOU THINK YOUR FINDING TDC MIGHT BE WRONG, AGAIN, I CAN GET IT 'SPLAINED PRETTY WELL
I'M SENDING "DAVID AND CHAD" TO GIVE YOU A HAND.....LET THEM EXPLAIN THIS A FEW TIMES BEFORE YOU "JUMP IN".....THEY DON'T MIND AT ALL!
CLASS 1
http://www.youtube.com/watch?v=5a2X9mSSlQY
CLASS 2
http://www.youtube.com/watch?NR=1&v=FHX1yXVyIMg&feature=endscreen
YOU AND I BOTH KNOW THIS IS GONNA TURN OUT TO BE SOMETHING OBVIOUS!
SEE YOU TOMORROW
THE MEDIC
Wednesday, December 10th, 2014 AT 8:37 PM
CJ MEDEVAC
  • 11,005 POSTS
BUSY DAY
TIME TO RELAX
PROGRESS?
THE MEDIC
Thursday, December 11th, 2014 AT 6:20 PM
SCHULTZ2659
  • 18 POSTS
Unfortunately I have not been able to do anything. I have hunters coming this weekend so I'm preping for that. Won't even see the jeep till Sunday at best.
Thursday, December 11th, 2014 AT 6:46 PM
CJ MEDEVAC
  • 11,005 POSTS
I UNDERSTAND
I'LL BE RIGHT HERE WHEN YOU RETURN
THE MEDIC
Thursday, December 11th, 2014 AT 6:51 PM
SCHULTZ2659
  • 18 POSTS
It lives!
Tuesday, December 16th, 2014 AT 1:55 PM
CJ MEDEVAC
  • 11,005 POSTS
WONDERFUL!
YOU PIC MAY NEED TO BE RESIZED TO GET IT TO WORK ON HERE
MAYBE THIS ONE WILL AID YOU MORE?
https://www.2carpros.com/questions/jeep-cj7-1985-jeep-cj7-stalls-when-hot
THIS WAS BACK SORTA WHEN I WAS NEW HERE, THEY CONVINCED ME TO CHANGE MY USERNAME (YOU'LL SEE IT), FOR SOME REASON THEY DIDN'T CARE MUCH FOR IT.
LET'S GET ANOTHER PIC ON HERE!
THE MEDIC
Tuesday, December 16th, 2014 AT 4:16 PM
SCHULTZ2659
  • 18 POSTS
Well here it is. I also change the speedo and instrument cluster
Wednesday, December 17th, 2014 AT 4:52 PM
CJ MEDEVAC
  • 11,005 POSTS
SO LIKE WE ARE REALLY HAPPY NOW?
IF SO
IF YOU EVER GET UNHAPPY AGAIN
YOU KNOW WHERE TO COME TO?
NICE JEEP!
KEEP IT THAT WAY!
I REALLY APPRECIATE THAT YOU HUNG WITH ME, I REALLY LIKE TALKING JEEP!
THE MEDIC
Wednesday, December 17th, 2014 AT 5:11 PM
