Jack of front of vehicle.
Put oil receptacle under engine.
Remove oil drain plug.
Allow oil to drain.
Remove oil filter with filter wrench.
Install new filter after applying a coat of engine oil to the gasket.
Hand tighten the filter as hard as you can get it to.
Install drain plug.
Lower jack.
Fill engine oil to maximum mark, overfill by about 4 mm.
Start engine.
Stop engine.
Recheck engine oil.
Top up if necessary
SPONSORED LINKS
Monday, October 8th, 2018 AT 11:41 AM
(Merged)
