1996 Ford F-150 idle
SLEE87
  • 1996 FORD F-150
  • 6 CYL
  • 285,000 MILES
I have a slightly rough idling problem which I cant seem to locate. In addition, sometimes at startup, the engine acts like its not getting enough fuel to run so I have to slam the accelerator down for only a second to keep it running
Wednesday, September 29th, 2010 AT 4:59 PM
CJ MEDEVAC
  • 11,004 POSTS
See my profile
I do not know your rig well
Are you showing a check engine light (if so Autozone or Advance Auto can test codes for FREE!)
I recently had a Similar issue on Wife's Ford Escape---No code thrown, It was the IAC. About $60, EZ to replace.
IAC is sorta the thing that controls Idle, it does not Meter in Fuel----It Meters in Air, to control idle speed. Its kinda a Air Bypass over the throttle butterfly.
Reply with good news!
Your Turn
The Medic
Wednesday, September 29th, 2010 AT 8:15 PM
