How to Reset an Oil Change Service Light
engine oil change reset lights
The engine oil life reminder light is designed to keep up on the maintenance of your vehicle. After an engine oil and filter change the light must be reset, we have gathered many popular procedures for turning off the service light for most vehicles which are listed below.
What Goes Wrong?
Some people forget to reset the oil life reminder after an oil change which results in an inaccurate oil life indicator for the next oil change. Resetting the oil life is free and easy to do.
GM Vehicles
  1. Turn the ignition switch to on (engine off)
  2. Press the accelerator pedal rapidly to the floor five times.
  3. Turn the ignition switch to the off position
  4. Repeat the procedure a little slower if needed
Chevy Cruze
  1. Turn on ignition.
  2. Push Menu button on the turn signal switch.
  3. Use the adjustment wheel and select the menu – Vehicle Information System.
  4. Use the adjustment wheel and select the menu – Oil Life System
  5. Push SET/CLR button on the turn signal switch and push brake pedal at the same time.
Chrysler Vehicles
  1. Turn the ignition switch to (engine off)
  2. Press the accelerator pedal slowly to the floor three times
  3. Turn the ignition switch to the off position.
  4. Repeat the procedure if needed
Ford Vehicles 2003 and Newer
  1. Press the Trip/Reset button and cycle to the Set-up Menu
  2. Select Reset
  3. Press and hold Trip/Reset button for approx two seconds and release the button when the Reset System message appears.
  4. Within two seconds, repress the button for approx two more seconds
    until “Oil 100% Reset if New” message is displayed and release the button
  5. Press the button once more to display “Hold Reset If
    New Oil” message is seen and release the button.
  6. Press the button once more press and hold it for approx two seconds
  7. Once the “Oil Life Set To 100%” is displayed, release the button and you are finished.
Ford Focus
  1. Turn the ignition key to the on position. Do not start the engine. For vehicles with push-button start, press and hold the start button for two seconds without pressing the brake pedal. DO NOT attempt to start the engine.
  2. Press both the accelerator and brake pedals at the same time.
  3. Keep both pedals fully pressed.
  4. After three seconds, the Service: Oil reset in progress. message will be displayed.
  5. After 25 seconds, the Service: Oil reset complete message will be displayed.
  6. Release both the accelerator and brake pedals.
  7.  The Service: Oil reset complete message will no longer be displayed.
  8. Rotate the key to the off position.
NOTE: For vehicles with push-start button start, press the start button to turn the vehicle off completely.
Ford Trucks
  1. Press and release the SETUP button until the message center displays OIL LIFE XXX% HOLD RESET = NEW OIL.
  2. Press and hold the RESET button for 2 seconds and release when the message center displays OIL LIFE SET TO XXX%.
  3. Press and release the SETUP button to exit the procedure.
Honda Vehicles
  1. Turn ignition to the run position (engine off)
  2. Press the Select button until the oil life message is displayed.
  3. Press Reset and hold for approx 10 seconds until the message maintenance reset appears.
  4. Press select and you will be prompted to select Y or N to complete the reset process.
  5. Select Y to reset the oil life indicator.
Jeep Vehicles
  1. Turn the ignition switch to the ON position (Do not start the engine).
  2. Fully depress the accelerator pedal, slowly, three times within 10 seconds.
  3. Turn the ignition switch to the OFF/LOCK position.
Lexus vehicles (pre 2008)
  1. The key should be in the off position.
  2. Press the trip reset button and while holding, turn the key to the run position (engine off)
  3. Continue holding the button until the odometer indicates 0
  4. Release the button to complete the procedure.
Mitsubishi Vehicles
  1. Turn the ignition key to the accessory position.
  2. Press the info button in the display until oil change information is displayed
  3. Press and hold the information button until the word clear appears.
  4. Release and press the info button again to complete the reset process
Nissan Vehicles
  1. Push the maintenance button on the main menu.
  2. Select engine oil and press enter
  3.  From the maintenance schedule, move the joystick right or left to select mileage interval.
  4. Select “Reset” and push enter.
  5. To complete the process, press and hold the maintenance button for 3 to 5 seconds.
Toyota Vehicles
  1. With the key in the off position, press and hold the trip/reset button.
  2. While holding the button down, turn the ignition key to “ON” position (engine off) and hold down the knob for approx five to 10 seconds.
  3. While holding the reset, the odometer meter will either show zeros or will show indicator lines which will flash. When they stop, it is finished.
  4. The system is now reset. Release the reset button and turn off the key.
Volvo Vehicles
  1. Turn the ignition key to position one.
  2. Select trip odometer 1. (note it must have a mileage reading and can not be 0)
  3. Press the reset button for approx 5 seconds or until the odometer shows 0
  4. While continuing to hold the trip button, turn the key to the off position
  5. When the odometer returns to its original mileage, release the button.
Watch the Oil Life Reset Videos!
Ford Explorer 2011-Present
Honda Civic 2006-2011
Saturn Vue 2002-2007
Toyota Camry 2007-2011
Questions?
Our certified technicians are ready to answer oil service reset light questions for free. We hope you saved money and learned from this guide. We are creating a full set of car repair guides. Please subscribe to our 2CarPros YouTube channel and check back often for new videos which are uploaded regularly.
Article published
