Overheating after changing the water pump, thermostat, sensor and radiator
SMITHCRYSTAL
  • 2002 PONTIAC MONTANA
  • 3.4L
  • 4 CYL
  • 256,000 MILES
No water in oil. No white smoke. I have bled it quite a few times to get air out of the coolant system. It continues to bubble off and on and it will get 3/4 of the way hot and then go back down to normal.
Monday, July 24th, 2017 AT 2:56 PM
CARADIODOC
  • 33,776 POSTS
The symptoms you listed are typical of a leaking cylinder head gasket. Your mechanic can perform a chemical test at the coolant reservoir to check for that. Do not go looking for the less common and more elusive stuff until the head gasket is ruled out.
Monday, July 24th, 2017 AT 8:34 PM
