After replacing water pump, thermostat, flushed radiator it overheats at idle
REDBONE
MEMBER
2002 PONTIAC MONTANA
3.4L
6 CYL
FWD
AUTOMATIC
170,000 MILES
Van has new water pump, thermostat, flushed radiator and it overheats at a idle. Could the heater core be bad?
Friday, January 27th, 2017 AT 4:29 PM
CARADIODOC
MECHANIC
If the overheating does not occur at highway speed when natural air flow through the radiator is sufficient, the best suspect is an inoperative radiator fan.
