1998 Toyota Corolla ENGINE STARTER REMOVAL
MARTINDINGER
  • 1998 TOYOTA COROLLA
Engine Mechanical problem
1998 Toyota Corolla 4 cyl Front Wheel Drive Manual
HOW DO YOU REMOVE THE STARTER MOTOR OFF A 4A-FE ENGINE?
Wednesday, September 3rd, 2008 AT 7:34 AM
MMPRINCE4000
  • 8,548 POSTS
Remove the negative battery cable first. Then the cable connection and solenoid connections to the starter.
The starter is usually held in place with two bolts, one one either side of the bell housing. Depending on the year, the starter can be located on the front or rear of engine.
Thursday, September 4th, 2008 AT 6:09 AM
