1989 Toyota Corolla Starting
JOELTYLER10
  • 1989 TOYOTA COROLLA
  • 4 CYL
  • MANUAL
  • 230,000 MILES
Whenever I try to start my toyota when its cold, it won't start unless I pour some gas into the carb. Why? Also when it does start its very rough and it hesitates a lot throughout acceleration. I already changed the fuel pump. What should I do? Any help in answering these questions would be greatly appreciated.
Saturday, January 16th, 2010 AT 5:35 PM
MMPRINCE4000
  • 8,548 POSTS
Check the bowl float, the float is not allowing enough gas into carb.
Sunday, January 17th, 2010 AT 6:52 AM
JOELTYLER10
Do I need to take off the carb to find this float? And my knowledge of cars is medium to average, is it something that I can change myself? Thanks in advance for your answers
Monday, January 18th, 2010 AT 4:11 AM
MMPRINCE4000
  • 8,548 POSTS
Yes remove carb. Float bowl allows a certain amount of gas so you do not stall car. The bowl itself may be worn to the point it needs replacing.
Monday, January 18th, 2010 AT 6:57 AM
