HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Engine
Starter
Replace/Remove
1989 Toyota Corolla Starter motor
ONHOJ
MEMBER
1989 TOYOTA COROLLA
4 CYL
FWD
AUTOMATIC
150,000 MILES
How do I replace it and where is it
Friday, July 16th, 2010 AT 6:01 PM
MMPRINCE4000
MECHANIC
Firewall side on trans bellhousing. Disconnect "-" battery cable, remove connections at starter, remove two bolts that hold starter, starter is heavy so be carefull.
SPONSORED LINKS
Saturday, July 17th, 2010 AT 8:33 AM
Please
login
or
register
to post a reply.
Related Starter Replace/Remove Content
1995 Toyota Corolla Replace The Starter Motor
How To Replace The Starter Motor? Thanks.
Asked by
wing
1995
TOYOTA COROLLA
VIDEO
Starter Replacement
Instructional repair video
GUIDE
Starter Motor Replacement
A starter motor is a high torque motor that utilizes a small pinion gear to contact the flywheel and a starter solenoid to initiate the electrical connection when the...
1990 Toyota Corolla Help! Need Help Changing Starter...
Hi, Friends. I Am In Need Of Help In Changing A Starter Motor For My Mother-in-law's 1990 Toyota Corolla. Its My First Time Changing The...
Asked by
JimmyL645i
1990
TOYOTA COROLLA
1995 Toyota Corolla Remove Starter
How Do You Remove The Starter
Asked by
vmsessions
1 ANSWER
1995
TOYOTA COROLLA
2000 Toyota Corolla Replacing Starter
Electrical Problem 2000 Toyota Corolla 4 Cyl Two Wheel Drive Automatic How Do I Replace The Starter In A 2000 Toyota Corolla
Asked by
mackman
1 ANSWER
2000
TOYOTA COROLLA
How To Change The Starter On The Toyota Corolla 1993
Battery Is Good It Click Once Only And All The Lights Work Everything It Was Running I Stop And I Try To Start The Car It Ticks Once Only...
Asked by
gaby
1 ANSWER
1993
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Starter Replacement
Starter Replacement
Online car repair manuals
