Hard/long start
WENNO
  • 2000 ISUZU AMIGO
  • 2.2L
  • 4 CYL
  • MANUAL
  • 6,000 MILES
The engine will start after turning over three to four times. Sometimes when the engine is warmed up it takes longer to start. I would like to know how to reset the timing. Spark plug and wires are new, firing order is right and I just replaced camshaft position sensor.
Monday, June 22nd, 2020 AT 8:16 PM
  • 108,427 POSTS
There is no timing adjustment. The timing signal is furnished by the crankshaft position sensor and the camshaft position sensor signal. The PCM controls the ignition timing.
I have to be honest, what you described doesn't sound like a timing issue but rather a fuel pressure issue. Do me a favor. Try this and let me know if there is any difference when starting.
1) Turn the key to the run position (engine off) and count to 5.
2) Turn the key off and then repeat step 1 three times.
3) On the forth time, start the engine.
Let me know if it starts easier for you.
Monday, June 22nd, 2020 AT 9:02 PM
