1998 Saturn SL2 car wont start
JOHNWYNN7611
  • 1998 SATURN SL2
1998 Saturn SL2 Front Wheel Drive Manual
my car wont start and I have change feul pump filter a bunch of stuff can u help
Wednesday, January 6th, 2010 AT 5:19 PM
SATURNTECH9
  • 30,869 POSTS
What is it doing when it doesnt start and what have u changed?The more details the better I can help u.
Wednesday, January 8th, 2020 AT 10:40 AM
JOHNWYNN7611
  • 9 POSTS
I have change the spark plug the thing that they plug into every one of the fuses
SATURNTECH9
  • 30,869 POSTS
So have u checked for spark?The best way to check for that is to remove two spark plug wires off the coils that are next to each other and have someone crank it over and watch for arching between the posts. Let me know what u find.
JOHNWYNN7611
  • 9 POSTS
We done that and it still wont crank the last time I drove it and when I cut it off it still run a little bit maybe 15 sec or so if that help we also check coil pack I am getten tired
JOHNWYNN7611
  • 9 POSTS
We change relays both coil the plate under the coil check the timing chain please help and god bless
SATURNTECH9
  • 30,869 POSTS
Does the engine turn over meaning is the engine spinning and not starting?If it does did u have spark?Did u check for spark?Lets stop replacing things and do the things I asked and get back to me that will the cheapest and quickest way to fix ur car.
JOHNWYNN7611
  • 9 POSTS
Yes it turn over and wont start no it dont have any spark
JOHNWYNN7611
  • 9 POSTS
And it not getten any feul
Wednesday, January 8th, 2020 AT 10:41 AM
SATURNTECH9
  • 30,869 POSTS
Ok no spark now were getting somewhere do u have a volt ohm meter if u do we can check ur crank sensor that's what I think is wrong with ur car since u don't have spark. If u have a volt ohmeter u can take out ur crank sensor and tested across the the two terminals it should read 800-1200 ohms when they go bad they read open no ohms value. Let me know what u find.
JOHNWYNN7611
  • 9 POSTS
Ok it took me a while to find that thing but I did and I chang it to and it still wont crank please help and god bless
SATURNTECH9
  • 30,869 POSTS
So u didnt check it u just replaced?Iam sorry I didnt mention where it was u should have asked me I wound have told u it was under the starter area. How do u know u dont have fuel pressure did u check it with a gauge or some other way?Do u have power and ground to the fuel pump?Did u check for spark the way I told u or some other way?Do u have any codes?Can a code reader read codes on ur car at all?Let me know.
JOHNWYNN7611
  • 9 POSTS
It wont let me even code it r nothing I dont no what else to do I have tried everything it not getting any power to the fuel pump and it still not getten any spark to
SATURNTECH9
  • 30,869 POSTS
Will the code reader power up off the car?It's begining to look like a bad computer after u tell me if the tool powers up off the car I can then get u the trouble tree for no communication with the computer. Have u checked all the fuses?Sorry it took me so long to get back to u I have been fighting with my plumbing and my plumbings winning. Let me know what u find.
JOHNWYNN7611
  • 9 POSTS
I think I fix it just got to put the computer in thank u so much I will let u now I get it started may god bless u so much
