HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Saturn
SL2
Fuel System
Fuel Pump
Fuel Pressure
1993 Saturn SL2 Fuel pressure
RPMCCAS
MEMBER
1993 SATURN SL2
4 CYL
2WD
AUTOMATIC
130,000 MILES
How much fuel pressure should a 93 Saturn have? Mine primes to 45 psi, then reduces to 35 while running.
Wednesday, February 17th, 2010 AT 7:51 PM
MECHANIC
FUEL PRESSURE SPECIFICATIONS
FUEL SYSTEM:
SOHC: Pressure at idle and 3,000 RPM.(26-31 psi)
DOHC: Pressure (Key ON/Engine OFF or Engine running/Wide open throttle: (38-44 psi)
DOHC: Presure at idle, 60 kPa vacuum: (31-36 psi)
SPONSORED LINKS
Wednesday, February 17th, 2010 AT 8:04 PM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Fuel Pressure Content
1995 Saturn Sl2 Dies After Running A Few Mins
This Sl2 Dies After Running Within A Few Mins. It Has Had 3 New Fuel Pumps Replaced. A New Fuel Filter Has Been Installed. After Installing...
Asked by
Carluccija
1995
SATURN SL2
1993 Saturn Sl2
I Have A 1993 Saturn Sl2 4dr Sedan 210,000 Miles. I Replaced Every Sensor My Idle Has Been Erratic For The Past 3 Months I Cleaned The...
Asked by
chrissy36nj
1993
SATURN SL2
1998 Saturn Sl2 Fuel Pump Relay
To Saturntch09: I Repaired My Ninitial Problem And Found A New Problem. Here Are My Both Stories. On My Initial Problem Of...
Asked by
GM1979
1998
SATURN SL2
What Would Cause No Fuel Pressure?
My Car Will Start For Me, Everything Running/sounding Normal. After A Couple Of Minutes, The Car Will Stall. Once The Car Stalls, I Do...
Asked by
sweetestcavaliar
1998
SATURN SL2
No Fuel To Schrader Valve After New Fuel Pump...
First, Would Crank Well But Not Start. Found No Fuel At Schrader Valve And Fuel Gauge Reading Empty With Tank Half Full. Cleaned Gas...
Asked by
GrandDad
2001
SATURN SL2
VIEW MORE
SPONSORED LINKS
Fuel Pump Replacement
Engine Not Starting - Top 3 Easy Steps
How to fix an engine that wont start
Online car repair manuals
