Crankshaft sensor?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,356 POSTS
Next up is to replace the crankshaft angle sensor. here is a video of the job being done on a similar car:
https://youtu.be/_xoGyRrHYbM
Monday, December 28th, 2020 AT 10:32 AM (Merged)
JIMB2020
  • 106 POSTS
I replaced the CKP sensor and the code cleared. But Joe (one of your experts) has been trying to help me with the fuel system fault (low fuel pressure) which I am still woking on.
JIMB2020
  • 106 POSTS
All done! Thanks to you and all of your experts. When I opened up the fuel tank and looked, I was shocked. The fuel pump barely bolted, its seals, nozzle and strainer were all at the bottom of the fuel container. The pump was pumping despite all this mess and obviously the in-line fuel filter had to bear the responsibility for filtering (it was changed many times in the past several years my sister tells me). After replacing the assembly altogether, I replaced the in-line filter and did voltage drop, resistance and continuity tests on all components. This morning (haven't gone to bed yet), I hooked up everything (well almost) and started the engine: The fuel pressure: 35 PSI and spec! (Up from 22 PSI). Fuel system fault: Clear. Have a good one and Happy New Year. James
KEN L
  • 43,356 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
