Reduced Power and Check Engine Light
BILLTHURSTON
  • 9 POSTS
Sorry it took so long. Cleared the codes and it finally gave me the reduced power and these are the codes P1125, P1295, @P1515. I know the P1515 is the reduced power. I looked up the other ones and I'm wondering if it is again the throttle position sensor. Again any help is appreciated. Thanks
Friday, January 8th, 2021 AT 9:27 AM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,571 POSTS
Hey Bill,
Yep its looking that the TP sensor is going or gone bad, try to replace it and let us know what happens.
Best, Ken
BILLTHURSTON
  • 9 POSTS
Is it the one on the gas pedal or the one on the engine
KEN L
  • 43,571 POSTS
If it has an electronic throttle its the one by the gas pedal, if not its the sensor by the throttle body.
BILLTHURSTON
  • 9 POSTS
Replaced the TPS by the peddle and so far it is working. My next question is what should the idle be. After its warm it is running around 775rpm. That is controlled through that sensor I just installed. You can adjust the peddle sensor. I think it should be around 6oorpm at warm idle.
CHASNESS
  • 2001 ISUZU RODEO
  • 3.2L
  • 6 CYL
  • 170,000 MILES
Reduced power light came on and vehicle would not go more than thirty mph and laboring at that. Replaced MAF, Throttle body and accelerator pedal sensor. Maf new TB and APS were used parts. Everything worked fine forabout fifteen miles then same problems manifest. Help Cecil, Help, at my wits end (short journey lol). God Bless Chas
HMAC300
  • 48,600 POSTS
Idle speed is controlled by pcm and should be 750 rpm. 25 rpm is nothing to try to adjust for
HMAC300
  • 48,600 POSTS
Scan for codes and check fuel pressure with a gauge auto parts rent it. also check for a vacuum leak.
BILLTHURSTON
  • 9 POSTS
Okay then thanks to all of technicians out there that assisted me. I will look at the site and see if in the future I can help out also.
RENEE L
  • ADMIN
  • 1,257 POSTS
Hi Chas,
If you decide you would like to conduct the scan yourself here is a link to an article that features written step by step instructions and pictures explaining how to do the scan yourself, also I have included a link to our YouTube channel with a how to video on code scanning. Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com
https://youtu.be/YV3TRZwer8k
Once you have the codes please get back to us so that we can further assist you. We are always happy to help.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
KEN L
  • 43,571 POSTS
That would be great, we help one person at a time get back on the road :)
CHASNESS
Thanks for replies. Limped into shop they hooked up their Hi-tech "$20,000" machine now they tell me passenger side catalytic converter is shot and needs replacing? Thoughts? I was going to put in a universal since both sensors are in pipe above and below catalytic converter. Thoughts?
CHASNESS
HMAC300 please advise on my 2001 reduced power post thanx God Bless Chas
HMAC300
  • 48,600 POSTS
Universal will work but not as long as original equipment or one made for your car. Was it a 430 code?
KEN L
  • 43,571 POSTS
Hi CHASNESS,
Please start a new question here https://www.2carpros.com/questions/new
Best, Ken
YAHAIRAT
  • 2001 ISUZU RODEO
  • 3.2L
  • V6
  • 180,000 MILES
The reduce power light came on while driving in Kissimmee, Florida. Temperature here is not cold, and now the truck wont start. It has done this in the past but goes away and does not come back for a few moths. Having to pay a tow truck almost $200 to bring back home, because the truck will not start up this time. As if the battery was dead or something.
In the past when it has done this, the truck would not turn off completely, but when trying to hit the gas, no matter how much, it would not go faster than 5-10 miles. Tried to crank, but would not do anything. How can I fix the issue? Please help!
YAHAIRAT
To the left of the A/T Oil Temp light it has the Reduced Speed light, it is on. The car will turn on and then turn off again. After that it won't turn back on. I have to wait at least an hour or two to try and turn on again. I am not able to take to scan, but will take all the help I can to fix myself.
Friday, January 8th, 2021 AT 9:28 AM (Merged)
KHLOW2008
  • 41,814 POSTS
When the engine could not be started, you need to find out what is missing. click the link below to find out how.
BEAT U
  • 2001 ISUZU RODEO
Engine Performance problem
2001 Isuzu Rodeo Question 6 cyl Four Wheel Drive
i have a 2001 isuzu rodeo, I put a cone air filter on about 2 months ago just recently my reduced power light comes on. Is my filter causing my light to come on or do I have a bigger prob
  • 31,937 POSTS
Hi there,
This filter may be restricted, is it a cleanable unit, if so give it a clean or replace it with the standard air filter and see how this works, run a scan as well just to check for any fault codes, start here.
Mark (mhpautos)
