No spark to the spark plugs
JOSE CHARLES
  • 1989 CHEVROLET CAMARO
  • 2.8L
  • 6 CYL
  • RWD
  • MANUAL
  • 104,780 MILES
The spark plugs are not getting any spark. What is the problem? Could it be a coil? Or something else?
Wednesday, December 7th, 2016 AT 8:17 PM
CARADIODOC
  • 33,763 POSTS
That's what you pay mechanics to diagnose. You must also check for fuel injector pulses and fuel pressure. That will tell you if you have a spark problem or a problem with something common to both systems.
You also have to consider a defective pick-up coil or ignition module. Those are both inside the distributor. Even the rotor can become shorted, but that is not very common with this distributor.
Friday, December 9th, 2016 AT 9:05 PM
