1997 Chevy Camaro
CARLOS_YADO
  • 1997 CHEVROLET CAMARO
  • 6 CYL
  • 145,000 MILES
Tires, spark plugs, and wires are good. It is 97 3.8 camaro, it used to shake sometimes when going up hill now it shakes when accelerating semi-fast, it is good when i'm at a red light and when accelerating slowly, I am thinking it is a sensor but am not sure, please help
Friday, August 7th, 2009 AT 12:13 PM
  • 108,544 POSTS
Does it seem like the engine is missing or could it be a bad universal joint?
Thursday, September 3rd, 2009 AT 9:28 AM
CARLOS_YADO
Yeah it seems to be the engine, when I press the gas pedal it shakes but stops doing it as it shifts into the last (fifth) gear
Monday, September 14th, 2009 AT 7:14 PM
  • 108,544 POSTS
Has the check engine light come on?
Monday, September 14th, 2009 AT 8:18 PM
CARLOS_YADO
No, the check engine light is not on
Monday, September 21st, 2009 AT 6:53 PM
  • 108,544 POSTS
If there is no light, I would start by looking for vacuum leaks and checking fuel pump pressure.
Monday, September 21st, 2009 AT 8:21 PM
CARLOS_YADO
Ok "Thank YOU", i'll check that out, I saw a way on youtube of how I can check for the vacuum leak but i'm not sure how to check the fuel pump pressure, but it's almost new so I don't think it would be that
Tuesday, September 22nd, 2009 AT 5:58 PM
