Camshaft Timing
ANONYMOUS
  • 1995 NISSAN PATHFINDER
I need the timing marks please
Wednesday, February 6th, 2013 AT 12:06 AM
KHLOW2008
  • 41,815 POSTS
Here is a guide and the diagrams below so you can see how the job is done.
https://www.2carpros.com/diagrams/nissan/pathfinder/1995
Wednesday, February 6th, 2013 AT 2:10 PM
ROBERTHEATH
  • 6 CYL
  • 4WD
  • 100,000 MILES
I need to get the timing sequence when I put the timing belt back on.
Wednesday, October 3rd, 2018 AT 6:55 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_823.jpg
FIG. 5
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_112.jpg
CHRISMOON
  • 3.0L
  • V6
  • MANUAL
  • 250,000 MILES
I need help with my 95 nissan pathfinder. I just rec busted a timing belt and bent all my valves so I took them to car city machine shop they rebuilt them and now I have the pf running but it's skipping and won't go iv checked timing 100's times still same 2 sets plugs will run and idle but just missing need help any answers
  • 108,186 POSTS
Has the check engine light come on to indicate which cylinders are misfiring?
RON1374
  • 8 POSTS
  • 1993 NISSAN PATHFINDER
  • 35,000 MILES
I was driving to work and my engine just died out.I thought I ran out of gas, I fueled up - turned on the key and noticed it was a timing belt problem just by hearing how it crank.I opened the front cam cover, the belt was striped up.I tried putting a new timing belt aligned both cam timing marks/crank pulley time mark I also set no.1 piston to TDC but it still wont turnover.I followed my chilton repair book step by step and still cant start. Could it be a bent valve e.T.C?Ive done timing belt issues before but a nissan pathfinder 93 VG30 seems difficult. Any good advice?
SATURNTECH9
  • 30,870 POSTS
Do a compression test on the engine that will tell you how the valves are bent or not. Let me kwow what you find.
You sure its on the compression stroke/TDC instead of exhaust stroke 180 out-double check
RON1374
  • 8 POSTS
How to tell the if the #1 piston TDC is on compression or exhaust stroke?
SATURNTECH9
  • 30,870 POSTS
If your cam and crank timing marks are dead on then you know your timed correctly. If they are do a compression test and post the results.
SATURNTECH9
  • 30,870 POSTS
Because that engine can bend valves.
LEDDFOOT
  • 1997 NISSAN PATHFINDER
  • 6 CYL
  • 25,000 MILES
I lost my book on the pathfinder, and I can't remember the tension on the pulley bearing fir the timing belt.
Torque on the tensioner pulley is 32-43ft lbs
RON1374
  • 8 POSTS
Timing marks matched up. It turned over but keeps dieing out.I think the distributor is off its mark, I cant seem to figure out the 15 degree mark or where to set the rotor.I removed the distributor a few times, advanced, & retard it. All it does is backfires- sometimes it stays running only when I gas it, but wont idle. What should I do?
Remove the distributor set the timing to 0/TDC at crank pulley and then reinstall the distributor making sure the rotor is pointing to the no.1 cap tower and then retime the ignition
SATURNTECH9
  • 30,870 POSTS
Also make sure the the cams are lined up so you know the valves are closed when it reads number one top dead center.
CADIEMAN
  • 3,544 POSTS
Im with rasmatas on this one my thoughts exactly.
BREANA386
  • 1994 NISSAN PATHFINDER
  • 6 CYL
  • 56,000 MILES
How do I set the timing if there is not marks to line the belt up with
Wednesday, October 3rd, 2018 AT 6:56 PM (Merged)
https://www.2carpros.com/forum/automotive_pictures/12900_nissan_timing_1.jpg
