1996 Nissan Altima number of problems
FROMAZ2VA
  • 1996 NISSAN ALTIMA
  • 4 CYL
  • FWD
  • 143,000 MILES
I have a 1996 nissan altima. In the past few months I have replaced the fuel pump and fuel filter. Changed out the spark plugs and wires. The problem that im haveing is when im at a dead stop and put on the gas to go it heistates and idels down then finally shuts off. Ive been told to do a number of things but I dont know where to begain and its really stressfull. O and the engine light does not come on. PLEASE HELP
Saturday, June 7th, 2008 AT 12:52 PM
KHLOW2008
  • 41,814 POSTS
Hi fromaz2va,
Sometimes sensors work inaccurately and the ECU is not smart enough to understand it. The light might not have come on and a scan will see whether there is any which you might not have noticed. The best way is to get a diagnostic done.
Most probable causes are the TPS and MAP/Mass sensor. However this is a drive by wire model, you need to look at the pedal side too.
Saturday, June 7th, 2008 AT 1:02 PM
FGLASS
Based on the mileage, I'll bet this was an
"oiled up distributor" from the notorious inner shaft of the distributor leaking
FGlass
Friday, July 11th, 2008 AT 11:24 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
A vacuum guage would be helpful in detecting ignition problems, mechanical problems and vacuum leaks. A vacuum leak can cause the problem you are experiencing, and they can be very frustrating to figure out. Using a can of carburetor spray, spray around your intake manifold and throttle body to see if this effects engine idle. Check all vacuum hoses. Just a different approach than the computer components.
Saturday, July 12th, 2008 AT 12:00 AM
