HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Expedition
Engine
Camshaft
Timing
SPONSORED LINKS
MY Expedition DOESN'T TURN ON ON FIRST CRANK
MEX919
MEMBER
2003 FORD EXPEDITION
5.4L
V8
4WD
AUTOMATIC
169,725 MILES
I have to crank my car a few times then it turns on and runs good what do you think it is I need?
Thursday, April 3rd, 2014 AT 4:25 PM
MECHANIC
Start by checking the fuel pressure if its within specs-
SPONSORED LINKS
Thursday, April 3rd, 2014 AT 8:33 PM
MEX919
MEMBER
Can it be a fuse or key switch you think?
Friday, April 4th, 2014 AT 7:28 AM
Please
login
or
register
to post a reply.
Related Camshaft Timing Content
Timing Marks Dont Line Back Up
5.4l Replaced Timing Chains And Everything Lined Up. Tensioners Are On And Looks Good. I Went To Spin The Motor By Hand To See If Everything...
Asked by
Diggy4u
1998
FORD EXPEDITION
1999 Ford Expedition
How To Tell If You Have A Bent Push Rod On A 1999 Ford Expedition. Had A Chipped Spark Plug On #3 Cylinder Idles Rough, Skipping, Lite...
Asked by
leressawise
1 ANSWER
1999
FORD EXPEDITION
1999 Ford Expedition Bent Push-pull Rod
Transmission Problem 1999 Ford Expedition V8 Four Wheel Drive Automatic How Do I Replace Bent Push Pull Rod
Asked by
Woody276276
1999
FORD EXPEDITION
2003 Ford Expedition Idle Air Control Motor
2003 Ford Expedition V8 Four Wheel Drive Automatic How To Fix This Is It Expensive? Will It Be Cheaper To Have It Done At Ford Dealer?
Asked by
marzree
1 ANSWER
2003
FORD EXPEDITION
2003 Ford Expedition Computer Messages
My Computer Keeps Telling Me My Door Is Ajar, And It Is Not. It Also Keeps Telling Me Check Charging System And I Did Just That And Battery...
Asked by
toddb47
2003
FORD EXPEDITION
VIEW MORE
SPONSORED LINKS
Camshaft Sensor Replacement
Engine Noises
Misfire
Online car repair manuals
