My car I just purchases a couple months ago used. I have come to find out that my heat works but does not get that hot. I was going to remove the thermostat and test it first. Ive also heard it could be the heater core but I have no problem with a leak in the area specified. Should I check that thermostat first?
SPONSORED LINKS
Monday, October 4th, 2010 AT 9:05 AM
WRENCHTECH
MECHANIC
With the engine at full operating temp, locate the 2 heater hoses where they go into the firewall and feel them to see if they are both hot to the touch. This guide can help us fix it
The temperature is controlled by the use of an air mix door that is operated by an electric motor/actuator. This door can be jammed or the actuator can be inoperative or have stripped plastic gears internally.
SPONSORED LINKS
Monday, October 4th, 2010 AT 9:13 AM
JEROME T
MEMBER
1 POST
2002 MAZDA PROTEGE
4 CYL
FWD
AUTOMATIC
120,000 MILES
02 mazda protege hardly blows any heat when heater is on, engine at operating temp, fan blows well
Monday, December 28th, 2020 AT 12:13 PM
(Merged)
MECHANIC
WIth the engine hot, running, and the heater on, feel both heater core hoses. If both are hot, check / repair the blend air door. If only one is hot, flush the heater core.
(Merged)
FRANKBEL
MEMBER
2000 MAZDA PROTEGE
175,000 MILES
My heater is blowing cold air. Any suggestions on what it could be? Does the heater have a fuse. Coolant is ok
(Merged)
MECHANIC
Is the engine warming up to a normal operating temp? Have you checked to see if both heater core hoses are getting hot? If they are, have you checked the blend air door?
SPONSORED LINKS
(Merged)
FRANKBEL
MEMBER
The hoses are warm and the door moves when I change settings
(Merged)
MECHANIC
If the hoses are hot and the blend air door is working, you should get heat. Are you sure they are hot and not just warm? Does the engine warm up to a normal operating temp?
(Merged)
FRANKBEL
MEMBER
The hoses are warm. The engine is warming. Does it have a fuse?
(Merged)
MECHANIC
There is no fuse for the actual heat. It is produced by the engine heating the coolant and then circulating it through the heater core. After that, the only thing that will stop heat (if everything is heating normally) is the blend air door.
(Merged)
FRANKBEL
MEMBER
So the actual heater core shouldnt be bad.I thought it had elements that heated up
(Merged)
MECHANIC
No, the heater core is like a small radiator that gets hot with coolant in it. If both hoses are getting hot, then you have circulation through it.
(Merged)
FRANKBEL
MEMBER
Ok thank you for your answers. Ill recheck everything. Thank you
SPONSORED LINKS
(Merged)
MECHANIC
Glad to help. Let me know what you find so I can direct you.
(Merged)
FRANKBEL
MEMBER
I will thank you.I will have to check it tomorrow.I greatly appreciate your help. Thankyou for responding so prompt. :)
(Merged)
MECHANIC
Glad to help.
(Merged)
FRANKBEL
MEMBER
Hey guys. Turns out my alternator belt was on the verge then broke off causing the waterpump to not work. Replaced the belt now I have heat. Thanks for your help.
(Merged)
FRANKBEL
MEMBER
Hey guys. Turns out my alternator belt to my waterpump was on the verge then btoke off. Causing no heat to the car. Replaced the belt all good now. Thank you for your help.
(Merged)
MECHANIC
I'm glad you got it fixed. Let us know if you have questions in the future.
(Merged)
GERMAN
MEMBER
1 POST
1995 MAZDA PROTEGE
4 CYL
FWD
AUTOMATIC
185,232 MILES
I just bought the car and the a/c blows normal air not cold like its supposed to and the heater blows the same as the a/c
Monday, December 28th, 2020 AT 12:14 PM
(Merged)
BMRFIXIT
MECHANIC
Check coolant level Is the car reaching operating temp Check heater core hoses if both are hot, if both hoses hot and not enough heat inside suspect blend door actuator if not one hose hot and the other warm or cold the heater core need to be flushed (very common)
