HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mazda
Protege
Engine Cooling
Water Pump
Replace/Remove
1994 Mazda Protege Removal and installation of water pump
VERNIEAJ
MEMBER
1994 MAZDA PROTEGE
4 CYL
FWD
MANUAL
99,600 MILES
What is involved in the removal and installation of the water pump? And, what tools are needed?
Saturday, March 22nd, 2008 AT 9:03 PM
VERNIEAJ
MEMBER
SPONSORED LINKS
Saturday, March 22nd, 2008 AT 9:05 PM
Please
login
or
register
to post a reply.
Related Water Pump Replace/Remove Content
2000 Mazda Protege Replacing Water Pump - Need Assist
I Am Working On Replacing The Water Pump (and Timing Belt) And I Am Having Trouble Removing The Failed Pump. The Inlet Pipe That Is...
Asked by
primemover
2000
MAZDA PROTEGE
VIDEO
Water Pump Replacement
Instructional repair video
2002 Mazda Protege Water Pump Replacement
I May Need To Replace Water Pump. What Is The Procedure? Are Any Pix Available? Really Need To Find A Repair Manual!
Asked by
garyhawaii
1 ANSWER
2002
MAZDA PROTEGE
How Do I Change The Water Pump On A 1993 Protege Dx...
I Have The Upper Timing Cover Off, Do I Need To Remove The Lower Section? How Many Bolts In The Pump? How Do I Remove The Timing Belt?
Asked by
moosehunter429
1 ANSWER
1993
MAZDA PROTEGE
1998 Mazda Protege Water Pump Replacement
How Often Should I Replace My Water Pump, And What Could Either Cause It To Deteriorate Prematurely Or Confuse A Mechanic Into Thinking It...
Asked by
auntiesmria
1 ANSWER
9 IMAGES
1998
MAZDA PROTEGE
Cooling System For Protege Es
I Have A 2002 Mazda Protege Es Model. The Car Has Had No Problems, Except: Major Cooling System Issues. I Just Got Word That My Second...
Asked by
katdy
1 ANSWER
2002
MAZDA PROTEGE
VIEW MORE
SPONSORED LINKS
Cooling System Pressure Test For Leaks
Coolant Leak Repair
Online car repair manuals
