HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Isuzu
Truck
Engine
Computer
Read Codes
SPONSORED LINKS
Where is the ODB output located?
PHICKS2121
MEMBER
1992 ISUZU TRUCK
1.0L
4 CYL
2WD
MANUAL
200,000 MILES
I have an odb2 reader but cannot find the cable on the pickup. Is it a 2-pick connector by trunk pull latch?
Then to read code short out the an and b; power on; no start. Read flashes with table on site?
Fix issue then ; pull neg for 30 sec? Is this right?
SPONSORED LINKS
Friday, May 19th, 2023 AT 10:42 AM
KEN L
MASTER CERTIFIED MECHANIC
This is because this truck does not have a OBD2 port.
Here is how the codes are retrieved in the guide below:
https://www.2carpros.com/articles/odb1-isuzu-1985-1994-cars-and-trucks-code-retrieval-procedure-and-definition
SPONSORED LINKS
Friday, May 19th, 2023 AT 12:37 PM
Please
login
or
register
to post a reply.
Related Engine Computer Read Code Content
Going Into Limp Mode
When Driving Along, The Trucks Service Light On Dash Comes On And Drops In Speed. When Turned Off And Back On It Will Run Fine For About A...
Asked by
Matt Quinn
2004
ISUZU TRUCK
1992 Isuzu Truck Ohms Resistance Of Oxygen Sensor...
Computer Problem 1992 Isuzu Truck 4 Cyl Two Wheel Drive Manual Is It Normal For The Oxygen Sensor Circuit Thru The Ecm Computer To...
Asked by
Carius Quesman
1 ANSWER
1992
ISUZU TRUCK
Pistons Hitting Valves
Here Are The Pistons Like Piston 4
Asked by
tanakaD
1 IMAGE
1992
ISUZU TRUCK
1987 Isuzu Truck Vacuum Hoses
Some Body Crossed My Vacuum Hoses As A Prank, I Need A Diagram For A 1987 Isuzu Pup 2.3 Gas
Asked by
mkent3006
1987
ISUZU TRUCK
Vacuum Hoses
Four Cylinder Two Wheel Drive Manual 159,000 Miles. I Bought The Truck Listed Above It Is The 2.3 Carburetor. I Took Off The Air Cleaner...
Asked by
threshertooth
1 ANSWER
1 IMAGE
1994
ISUZU TRUCK
VIEW MORE
SPONSORED LINKS
Oil Change and Filter Replacement Subaru
Oil Change and Filter Replacement - Ford F150
Oil Change & Filter Replacement Toyota
Online car repair manuals
