HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Odyssey
Ignition
Spark Plug
Replace/Remove
2002 Honda Odyssey Spark Plugs
REYNOLDSDD
MEMBER
2002 HONDA ODYSSEY
6 CYL
FWD
AUTOMATIC
142,000 MILES
How often do you need to change the spark plugs. Where can I find a maintenance guide to tell me what needs to be done when?
Monday, September 29th, 2008 AT 3:45 PM
KHLOW2008
MECHANIC
Hi reynoldsdd,
Spark plugs replacement depends on the usage and type used.
Normal plugs should last between 10 to 15 k miles. If it is the platinum type, it can last up to 60k miles.
The maintenance schedule is found in the owners manual and if you don't have t, you can try getting it from Honda.
SPONSORED LINKS
Saturday, October 11th, 2008 AT 3:25 PM
Please
login
or
register
to post a reply.
Related Spark Plug Replace/Remove Content
2002 Honda Odyssey Spark Plug Replacement
Hi, I Recently Had The 90k Service Done On My 2002 Honda Odyssey. It Incl Spark Plug Replacement. When I Got Back My Car, I Was Chrged A...
Asked by
kiranmr28
1 ANSWER
2002
HONDA ODYSSEY
VIDEO
Spark Plug Replacement Honda
Instructional repair video
GUIDE
A spark plug is a vital part of the engine's ignition system and is responsible for starting the combustion process. As a part of an engine tune up, spark plugs should ...
Oil On Spark Plug Causing Misfires
Oil Leaking In Spark Plug Tube Shorting Out The Spark Plug Causing Misfire In Our 2006 Honda Odyssey. Can You Recommend The List Of...
Asked by
kdogshopping
13 IMAGES
2006
HONDA ODYSSEY
2001 Honda Odyssey Several Cyl Solenoids Burned One...
At Some Point The Van Started Shaking When The Engine Was Running. I Took It To A Mechanic Who Said That On 2 Cylinders The Solenoids Were...
Asked by
ilyaz
2001
HONDA ODYSSEY
2000 Honda Odyssey Spark Plugs
How Do I Access And Replace The Spark Plugs And Spark Plug Wires In My 2000 Honda Odyssey? I'm Pretty Mechanically Minded And Have Done A...
Asked by
madd_dadd
1 ANSWER
2000
HONDA ODYSSEY
2007 Honda Odyssey Stephen's List
How Do I Access And Replace The Spark Plugs And Spark Plug Wires In My 2007 Honda Odyssey-touring Model?
Asked by
smestel
1 ANSWER
2007
HONDA ODYSSEY
VIEW MORE
SPONSORED LINKS
Spark Plug & Wire Replacement Chevy Avalanche
Spark Plug Replacement Ford Escape V6 3.0L
Spark Plug Replacement Honda Element
Online car repair manuals
