02 sensor location and replacement
E. ANDY
  • 2002 HONDA CRV
  • 4 CYL
  • 4WD
  • MANUAL
  • 130,000 MILES
Recently I changed my 2002 Honda CR-V catalytic converter and replaced it for about $550. The check engine light came back on again after a couple of months. I took it to another dealer and was told I need to change the oxygen sensor (code:P1166). Shouldn't the first dealer detected the problem in the first time? Did he fail to note the real problem (the oxygen sensor) and change the wrong part?
Your professional advise is highly appreciated.
Wednesday, January 16th, 2019 AT 6:39 PM (Merged)
  • 108,289 POSTS
Honestly, I would need to know what codes he found at the first shop. There is a chance that the O2 sensor went bad after the fact. By any chance do you have the original trouble code that was found?
KHALED
  • 2002 HONDA CRV
  • 4 CYL
  • 4WD
  • 109,000 MILES
One month ago, I had a yellow light with the shape of the engine. I took my car for check up, the technician told me that I have a problem with the o2 sensor he reseted the light and he tolld me I can keep driving my car untill I feel that its fuel consumption is higher than normal then I have to change the o2 sensor. The light now appears for 2 or 3 days, after it went off for 2 or 3 days. Please advice me what to do and what are the problems that I might face if I kept driving my car without changing the o2 sensor.
F4I_GUY
  • 3,302 POSTS
https://www.2carpros.com/articles/how-an-oxygen-sensor-works
That is an article explaining how oxygen sensors work. If your oxygen sensor is reading improperly you will suffer an increase in fuel consumption which can also warm your engine. Fuel contaminates engine oil, may damage catalytic converters as well. The code may of been for the heater circuit as well, which just indicates that your oxygen sensor is not heating up fast enough according to OE spec.
LARRY ZHANG
  • 2004 HONDA CRV
  • 4 CYL
  • 4WD
  • 70,000 MILES
How can I instal front oxygen sensor by myself. I already bought the part.
Thanks a lot!
BLUELIGHTNIN6
  • 16,542 POSTS
Just unscrew it and unplug the electrical connections and reverse procedure for installation
thanks for using 2CarPros. Com!
