There is no spark?
KHLOW2008
  • 41,814 POSTS
You're welcome.
With ignition switch turned on, dash indicators showing and no power to distributor would mean a break in the wiring circuit.
Now would be the difficult part. Locating the source of the break.
Monday, November 2nd, 2020 AT 1:28 PM (Merged)
BLACKOP555
  • 10,371 POSTS
Sounds like yoru not getting an ignition pulse. Possibly bad icm or crank sensor but what you should do first is to put a noid light in between th power and ground on coil and crank. Does it flash?
AUSTINMARTIN
  • 31 POSTS
I got the black and yellow wire to have power now. But it wont turn over now.
KHLOW2008
  • 41,814 POSTS
How did you do that?
Now you need to test for battery voltage to the starter solenoid.
High possibility you have a bad ignition switch.
AUSTINMARTIN
  • 31 POSTS
Today when I went to test the black and yellow wire it had power but then it wouldnt crank.
KHLOW2008
  • 41,814 POSTS
Did you test the starter solenoid wire for battery voltage at cranking position?
AUSTINMARTIN
  • 31 POSTS
No I did not.
KHLOW2008
  • 41,814 POSTS
If you don't want to do any testings, how do you expect us to help you?
AUSTINMARTIN
  • 31 POSTS
The little wire to the starter solenoid does not have power
AUSTINMARTIN
  • 31 POSTS
When you try and crank the car
KHLOW2008
  • 41,814 POSTS
The same wire is powered from the ignition switch. Try same procedure and test at ignition side for the same wire. If voltage is not available, you have a faulty ignition switch.
AUSTINMARTIN
  • 31 POSTS
Found out it was a bad connector under the hood.
KHLOW2008
  • 41,814 POSTS
Nice
AUSTINMARTIN
  • 31 POSTS
Thank you for the help.
KHLOW2008
  • 41,814 POSTS
You 're welcome.
