Dash lights not working
WRENCHTECH
  • 20,758 POSTS
You can bet there is a blown fuse there somewhere. You have apparently wired it wrong. We see this all the time with people installing their own stereos and it often does a lot of damage. They make adapter harnesses for doing this correctly. If you went and cut your harness, it's probably too late already and you will have to bring it to an electrical specialist.
Thursday, August 1st, 2019 AT 5:19 PM (Merged)
FAFII7
  • 5 POSTS
Do you know which fuse it will be that could be blown?
WRENCHTECH
  • 20,758 POSTS
There are numerous fuses being used. You need to use a test light on both sides of every fuse wit the lights turned on.
FAFII7
  • 5 POSTS
Ok ill do that and I bought the adapter from wal mart and there was this orange wire that says dash light but there was no were to connect it to so I just left it hanging and taped it could that be the issue also?
WRENCHTECH
  • 20,758 POSTS
Disconnected wires at the radio won't cause you to lose the rest of the dash lights.
FAFII7
  • 5 POSTS
Oh ok its just my cluster lights dont work everything else is fine
DENNIS234
  • 1995 HONDA ACCORD
  • 4 CYL
  • 113,000 MILES
Where is the fuse, located for the dashboard ligts
KHLOW2008
  • 41,814 POSTS
Hi dennis234,
If the taillights are not working, then it could be the fuse. # 32 ( 15A ) under hood.
If not, you need to check the integrated control unit and/or meter cluser.
CJ MEDEVAC
  • 11,004 POSTS
You don't reckon you turned your cluster illum. Dimmer switch down/ off and didn't realize you did?
Sometimes when you have really good help from the neighbor or the youngins, they mess with stuff while they are leaned in there talking to you!
The medic
FAFII7
  • 5 POSTS
Yeah the switch is on its just the cluster that doesn't work and I hate it cause I cant see how fast I'm going at night :/
TCMEHLHORN
  • 1994 HONDA ACCORD
  • 4 CYL
  • FWD
  • 130,000 MILES
The dashboard lights do not work; panel lights work until I turn headlights on, then all dash and center consol lights inop
Thursday, August 1st, 2019 AT 5:20 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Are the taillights working?
Have you checked the dimmer control?
Was the radio replaced?
When did this occur?
RYAN14CHRIS
  • 1990 HONDA ACCORD
  • 180,000 MILES
When signaling to turn, no matter which way I am turning, BOTH of my turn signal dashboard lights flash. What does this mean?
KHLOW2008
  • 41,814 POSTS
A bad ground circuit connection. Check the exterior turn signal lights to see if they are working correctly.
