Speedometer does not work?
KHLOW2008
  • 41,814 POSTS
Hi PANTERANEGRA,
Seems you are describing a DTC code # 10 instead of # 1.
1 should be a short quick flash and a prolonged flash before it goes off is 10.
DTC # 1 = Lockup solenoid valve A problem.
DTC # 10 = Disconnected Engine Coolant Temperature sensor.
The symptom does not tally with the codes on display and I believe you need to substitute a TCM totest.
Tuesday, July 14th, 2020 AT 12:58 PM (Merged)
PANTERANEGRA
  • 12 POSTS
Thank you for the replay KHLow2008 I agree. The light doesn't seem to be giving me a code. Can you tell me a little bit about how the transmision work. Is it controlled electronically. It seem to be acting up more now i'm not sure I it is related to the car getting warm(from drivig) because when I leave the house it works fine.I drive about 14 miles to work and about 8 to 10 miles the transm. Goes into low gear and stays there then it will act ok and switch back to low gear soemtimes after I turn off the car when I run into the store and go back in the road it works fine for a mile or so then goes back to low gear.
Thank you for your help
KHLOW2008
  • 41,814 POSTS
Hi PANTERANEGRA,
DESCRIPTION
Automatic transaxle is electronically controlled. Transaxle shifting and torque converter lock-up are controlled by Automatic Transaxle Control Unit (ATCU) for optimal performance. The ATCU receives information from various input devices and uses this information to control shift and lock-up control solenoid valves.
Vehicle is equipped with "S" (sport mode) switch mounted on shift lever in the vehicle. The "S" switch is used to change shift points under part throttle acceleration. When "S" switch is depressed with ignition on, "S" indicator light on instrument panel should come on and then go off when "S" switch is released.
Your symptom is consistent with a faulty TCM or its wire connections. When cold the TCM works ok, when heated up, resistance builds up or some of the TCM internal capacitors etc stops and when the brain senses a fault, it goes into fail safe mode (limp mode). When you turn ignition off, the TCM iresets and restarts woould have the TCM working normally till it senses any faults.
PANTERANEGRA
  • 12 POSTS
Hi KHLow2008 I went back and pulled the ATCU and looked at it better this time and found a capacitor that had leaked on the circuit board so I cleaned the board well and found traces that were open(corroded by the leaking cap.) I put a couple of jumper wires replaced 2 capacitors also I pulled the ECM and cleaned the conector's plug on both of these assemblies there were some corrosion on both assemblies and the car works good so far now only one thing to do is to conect the S switch and see if it works.
Thank you for the information and your help.
I have a couple more questions about the same car.
1. The car has 140,000 miles and transmision oil has not been changed in a long time not sure how long. Do recomend changing the oil now?
2. The driver side window motor is bad. Any TIPS on replacing it?
Thank you
KHLOW2008
  • 41,814 POSTS
Hi PANTERANEGRA,
If the color of the trans fluid looks dark or brownish, it is best replaced. If it is bright red, it is still in good condition.
Regarding the window motor, what is the problem that you are facing? If it is sluggish, it usually is caused by the runchannels and not the motor. If the runchannel is distorted, especially near the wing mirrors, you need to replace it.
PANTERANEGRA
  • 12 POSTS
The car is runing good now execept that the brakes giving me problems.
When I stop at a signal light the brake pedal starts to go lower and lower.I have purge the brakes, check for broken hoses around the booster. Any ideas.
Thank you
KHLOW2008
  • 41,814 POSTS
The symptom indicates a failing brake master cylinder which is leaking internally. You need to repair/replace the master cylinder and bleed the system to rectify.
BHOPPER7019
  • 1989 HONDA ACCORD
  • FWD
  • MANUAL
The speedometer on my 89 honda accord has always bounced when driving then one day it just stopped working how do I fix this problem
MIKE H R
  • 3,094 POSTS
The bouncing comes from the cable binding up in the housing. Remove the speedometer gear from the transmission then remove the speedometer cable. Try pulling it out of the housing. If it is broken then you will have to disconnect it under the dash at the sppedometer. With it broken you may have to get a complete cable assembly.
MBACLEANER
  • HONDA ACCORD
I have a 92 Honda Accord EX wagon with 212k miles on it. Not long ago, the speedometer would sometime work and sometime not work. It is now completly dead and shows no speed when driving. I suspect that it is the combination meter that has stopped working.
Two questions, does this problem sound like a combination meter malfunction and secondly, if so, where is the meter located?
Regards,
NT
BRUCE HUNT
  • 3,754 POSTS
Do you have a tach on the vehicle? If so does it still work? If not, I would suspect the sender and if so, the speedometer.
MBACLEANER
All other guages as well as the tach are all working properly.
BRUCE HUNT
  • 3,754 POSTS
I would give the nod to the speedometer itself having failed. The sender is doing its job.
ARCHBUNK
  • HONDA ACCORD
I got a 1990 Honda accord automatic with 150,000 miles. The green S light will come on some times while driving and speedo will quit working. Is this some kind of check trans light and if so how can I read trans codes. Thanks for your help
USPSTECH
The "Sport" lamp is used for reading diagnostic trouble codes by jumpering the diagnostic connector and counting the flashes. Your shift concerns and your speedometer are one in the same problem. Replace the Vehicle Speed Sensor.
CSANDERS3
  • HONDA ACCORD
I had my alternator replaced yesterday on 1987 Honda Accord DX and a tune up, today my speedometer isn't working; any idea what the problem could be? If it's replacing the speedometer or cable, is that expensive?
BRUCE HUNT
  • 3,754 POSTS
No not really because you will likely only find used parts and they are reasonable. I would check to see that nothing was disconnected during the alternator replacement and forgotten to be reconnected.
