Hard starting
INTREPID2002
  • 2002 DODGE INTREPID
  • 3.6L
  • V6
  • 127,000 MILES
Car starts eventually, not right away. Thought it was the battery so made the purchase for new one. Still has the same problem. The check engine light comes on after the starting process. Otherwise it drives and handles really good. What do I need to correct the hard starting and make check engine light go off? Thanks.
Wednesday, March 8th, 2017 AT 7:01 PM
HMAC300
  • 48,600 POSTS
You need to scan for codes then use a scanner to turn off light. but get code first, then check fuel pressure with a gauge auto parts rent it. See link.
Thursday, March 9th, 2017 AT 6:06 AM
INTREPID2002
Thank you for your speedy reply HMAC300! I will let you know how your advice turned out for me. :)
Thursday, March 9th, 2017 AT 6:48 AM
