HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Ranger
Fuel System
Fuel Pump
Not Working
Frame mounted fuel pump not coming on.
JIMMIE ANTHONY
MEMBER
1988 FORD RANGER
2.9L
6 CYL
2WD
AUTOMATIC
120,000 MILES
Need a complete wiring diagram for the frame mounted fuel pump 88 Ranger 2.9 2wd
Monday, February 15th, 2016 AT 8:02 PM
WRENCHTECH
MECHANIC
This is a single tank circuit.
SPONSORED LINKS
Tuesday, February 16th, 2016 AT 2:20 AM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Not Working Content
Fuel Pump Won't Come On
My 94 Rangers Fuel Pump Will Not Come On. New Pump & Filter. Can Connect From Battery To Pump And Comes On But Not When You Turn The...
Asked by
Ranger1976
13 IMAGES
1994
FORD RANGER
Bad Fuel Pump?
I Have A 2003 2.3l Ford Ranger With Only 50k Miles And I Am Having (i Believe To Be A Fuel Delivery Problem). I Was Driving Fine Around 65...
Asked by
tiguepotter1
11 IMAGES
FORD RANGER
Fuel Pump Problem
I Was Driving Then All Of A Sudden Truck Quit Running And Fuel Pump Will Not Turn On With Switch, All Fuses And Relays Are Working, I Have...
Asked by
jessejames921
1993
FORD RANGER
Fuel Pump
The Fuel Pump Will Not Come On When I Turn The Key To On Or When Cranking. What Could Be The Cause?
Asked by
joe1953
1999
FORD RANGER
Fuel Pump Keeps Shutting Off
The Fuel Pump Either Comes On Or Does Not. I Wait Then It Will Start Then While Driving It Shuts Off. I Wait Try It A Few Times Listening...
Asked by
mistymay
1 ANSWER
1994
FORD RANGER
VIEW MORE
SPONSORED LINKS
Fuel Pump Replacement
Fuel Pump Pressure Test
Engine Not Starting - Top 3 Easy Steps
Online car repair manuals
