1997 Ford Ranger Fuel Filler Hose
STRAND2001
  • 1997 FORD RANGER
  • 4 CYL
  • 99,000 MILES
I am looking to buy the rubber hose that leads from the gas cap to the fuel tank with the metal vent tube inside and I do not know the exact part name could you help?
Sunday, December 30th, 2007 AT 12:54 PM
MERLIN2021
  • 17,251 POSTS
Thermostat is a good start! May be the waterpump, I have seen the vanes actually corode. See if you can tell if the coolant is circulating. Look in the recovery bottle for swirling action.
Friday, November 23rd, 2007 AT 7:36 PM
CANDTALWAYS
  • 9 POSTS
93 f150 351, I just had the waterpump replaced about 4 months ago. Could it go bad in such a short period of time, also I though if the waterpump was bad there would be a small leakage from the weep hole on the pump?Also I flushed the radiator system out a couple months after having it put on and it was alot of rust. Should I still look into having the waterpump changed and is there anyway to test it to see if its bad?
Thanks for the reply.
Friday, November 23rd, 2007 AT 9:28 PM
CANDTALWAYS
  • 9 POSTS
I've looked in the recovery unit and I didn't see any kind of swirling motion. Is this a good thing or is it suppose to have some sort of swirling motion?Also I changed my thermostat and it still runs hot.I was wondering if perhaps it could be a faulty temp sensor?
Saturday, November 24th, 2007 AT 7:09 PM
98RANGERXLT
  • 301 POSTS
Do what justan old told you then get back to us
Monday, November 26th, 2007 AT 7:30 PM
BLACKOP555
  • 10,371 POSTS
The name is the fuel filler hose.
Sunday, December 30th, 2007 AT 1:32 PM
