1987 Ford Ranger fuel line
MMMGETUM
  • 1987 FORD RANGER
  • 6 CYL
  • 144,000 MILES
I'm having a problem with a fuel pump, filter or a regulator. There is fuel up to the filter and its not clogged. I put gas in the injectors it runs till the gass is out of it. There is a crack in the vacuum line of the regulator could this be the problem? Is there anyway I can get like a blueprint for the fuel system it looks like there is two pumps under the frame before it gets to the filter?
Wednesday, June 17th, 2009 AT 6:16 PM
BLACKOP555
  • 10,371 POSTS
Check the fuel pressure at the rail.
Do you have dual tank?
There is a pump in the tank.
Then goes to the dual fuel tank selector valve if you have dual tank. Then it goes to the highpressure pump as the low pressure pumps are in the filter.
From there it goes into the fuel filter then to the rail. And back to the tank.
Wednesday, June 24th, 2009 AT 8:33 AM
