Ford F-150 Ethanol
TERBOB
  • 1915 FORD F-150
Noises problem
Ford F150 V8 Four Wheel Drive Automatic 130000 miles
I recently added 3/4 of a tank of Ethanol to my unleaded fuel tank. Immediately after I noticed a sound and slight vibration. What can I do to prevent this from doing serious damage to my truck? Will this problem go away by adding in unleaded gas slowly to the tank of mixed fuel? The Engine is a 4.6L and the Mileage is in kms. Thank you for any help you can provide.
Sunday, November 22nd, 2009 AT 7:33 PM
  • 108,550 POSTS
What year is the truck? Is it designed to run ethanol? It should clean itself up after that fuel is gone. Don't expect good fuel economy. And yes, I would add regular fuel when as the tank gets low enough to do it.
Sunday, November 22nd, 2009 AT 8:30 PM
TERBOB
The truck is a 2003. It is not designed to run on Ethanol. Thank you for the information. Have a great day.
Monday, November 23rd, 2009 AT 6:22 AM
  • 108,550 POSTS
You may want to consider draining it if the truck isn't designed for it.
Monday, November 23rd, 2009 AT 7:20 AM
EDDY2000
  • 9 POSTS
From what i`ve read it shouldn`t hurt but I wouldn`t do it again. Unless your vehicle says flex fuel it isn`t made to run ethanol. Most stations have 10% added but i`m told it won`t hurt.
Thursday, November 26th, 2009 AT 4:14 PM
