HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Fuel System
Tank
SPONSORED LINKS
2005 Ford F-150 code P1450
CABRALRODNEY
MEMBER
2005 FORD F-150
V8
2WD
AUTOMATIC
75,000 MILES
Code says unable to bleed vacumm from gas tank. When I open gas tank it has a hissing sound
Sunday, July 25th, 2010 AT 5:35 PM
MECHANIC
There is a one way vent that allows air to enter the tank while fuel is pumped to the engine. Check to make sure it isn't plugged or damaged.
SPONSORED LINKS
Monday, July 26th, 2010 AT 12:08 AM
CABRALRODNEY
MEMBER
1 POST
Where is the vent
Monday, July 26th, 2010 AT 10:33 AM
MECHANIC
Check on the rear of the tank. It should come from the sending unit area.
Monday, July 26th, 2010 AT 11:45 PM
Please
login
or
register
to post a reply.
Related Fuel System Tank Content
1994 Ford F150 Front Gas Tank Expelling Gas
Engine Mechanical Problem 1994 Ford F150 Engine Size Unknown Two Wheel Drive Automatic 185600 Miles I Have A '94 Ford F150 Xlt With...
Asked by
AngieH
1994
FORD F-150
VIDEO
How to Siphon Fuel
Instructional repair video
Fuel Tank Switch Location?
My Fuel Tank Switch Does Not Work. I Switch It From The Rear Tank To The Front Tank And It Drops To Empty And The Truck Dies. The Front Tank...
Asked by
bgreene2025
1992
FORD F-150
1980 Ford F150 Fuel Tank Repairs
Alright, We Are Trying To Resurrect A 1980 Ford F150 2x4 That Has Been Sitting 10 Years. We Have Read Articles And Managed To Start Up The...
Asked by
swanson93
1 ANSWER
1 IMAGE
1980
FORD F-150
1989 Ford F150 Fuel Tank Switch Inoperative
When Trying To Switch Between Fuel Tanks, I Notice That Nothing Happens When I Flip The Switch Back And Forth. Is This A Solenoid Issue?
Asked by
jonas.calsbeek
1989
FORD F-150
Starts After Hearing A Pop Coming From The Fuel Tank
When Cold Outside Truck Does Not Start. I Can Hear The Fuel Pump Working In The Rear Tank Which Is The One I Am Using. After I Hear A Pop...
Asked by
Joseph-Robin Poulin
1 IMAGE
1994
FORD F-150
VIEW MORE
SPONSORED LINKS
Fuel Pump Replacement
Fuel Pump Pressure Test
Fuel Injector Replacement
Online car repair manuals
