What tool do I use to remove manifold bolts connected to catalyti converter on passenger side?
Tuesday, June 22nd, 2010 AT 4:27 PM
MECHANIC
Hi:
I'm not sure what you are asking. The converter is a seperate unit from the manifold on both the 5.4L and the 4.6L. Here is a picture of the manifold. Tell me if it is what you are refering to. As far as the catalytic converter, it come off the Y-pipe. If I recall, they are either a 9/16 nut or maybe a 15mm.
