1994 Ford F-150 runs rich black smoke out the pipe
1954ALAN
MEMBER
1994 FORD F-150
V8
4WD
AUTOMATIC
83,000 MILES
All of a sudden when I started the truck it ran rough and smoked indicating a rich fuel condition. I drove the truck about 25 miles and the disconnected the battery, checked the intake and air filter wich was all good and then reconnected the battery and the truck ran normal. Drove the truck the next day and all was fine. Drove the truck later in the afternoon and the problem was back.
SPONSORED LINKS
Wednesday, August 4th, 2010 AT 4:22 PM
MECHANIC
Have you checked fuel pump pressure? You may have a bad regulator causing the pressure to get too high? Also, has the check engine light come on?
Wednesday, August 4th, 2010 AT 6:11 PM
1954ALAN
MEMBER
Pulled the vacum hose off the regulator engine running and fuel was coming out of the regulator, installed a new regulator all is normal
SPONSORED LINKS
Wednesday, August 4th, 2010 AT 6:23 PM
MECHANIC
That will do it. I'm glad you got it fixed and let us know if you have questions in the future.
