2001 Ford F-150
JGL1512
  • 2001 FORD F-150
  • V8
  • 4WD
  • 150,000 MILES
Service engine light on. Sounds like exhaust leak. Engine cuts out. Used to be only at low speeds now getting worse. Replaced egr valve and hose. Any thoughts?
Wednesday, September 16th, 2009 AT 6:23 AM
  • 108,262 POSTS
Have you had the computer scanned for codes?
Wednesday, September 16th, 2009 AT 7:15 AM
JGL1512
Yes I had it scanned. Out local guy just said it read "emissions" that is when he replaced the egr. Thanks
Wednesday, September 16th, 2009 AT 10:45 AM
  • 108,262 POSTS
Have they checked the catylatic converter? Fuel pump pressure? Also, does this have the 5.4L V8? If so, chances are the exhaust manifold bolts are breaking and causing a manifold leak. This is a common problem and not an easy one or cheap one to fix. If you can't get the bolts out, the head has to come off.
Wednesday, September 16th, 2009 AT 11:18 AM
