1992 Ford F-150 quit running!
ILLINOISDUDE11
  • 1992 FORD F-150
  • V8
  • 125,000 MILES
I was driving the truck down the road it stopped running just light I turned the key off, i, m leanning towards a ignition control module, I took a test light and i, m getting power too the wire too the module and when I have a friend crank it the light flashes on the test light cab you help me
Thursday, February 5th, 2009 AT 3:13 PM
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Thursday, February 5th, 2009 AT 3:19 PM
ILLINOISDUDE11
Yes we done all that had power too the coil, we are getting fuel, no spark, how do you determine if the control module bad !
Thursday, February 5th, 2009 AT 3:34 PM
You need a special tester to determine it-Did you test the distributor pick-up coil and the coil's primary and secondary resistances?
Thursday, February 5th, 2009 AT 9:31 PM
RANGERDANGER17
  • 224 POSTS
Check the timing belt
Sunday, February 8th, 2009 AT 2:34 PM
