1998 Ford Contour timing belt broke
SUPERFITZ
  • 1998 FORD CONTOUR
1998 Ford Contour 4 cyl Front Wheel Drive 90000 miles
Everyone tells me I have bent valves, because the belt broke and the head has 0 clearance. The bolts in the head are covered by the cams. The rear cam lift out easy but the front cam is different. I'm having a problem with the intake. If I let it go from the head, does come off with the intake? I worked on cars in my teens, it was easier and a lot more room to work. How do you donate?. RAY
Wednesday, April 15th, 2009 AT 8:17 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello Ray
Thanks for the donation
The DOHC engine is a non-interference designed engine. The valves would not have been damaged by the timing belt breaking. You can confirm this by contacting your local Ford dealer and ensuring it is indeed a non-interference engine before you start tearing it apart to inspect it.
Let me know if you need further assistance.
Thanks for using 2CarPros. Com!
Wednesday, April 15th, 2009 AT 11:43 AM
