1997 Ford Contour horn not working
JIMMY46
  • 1997 FORD CONTOUR
  • 4 CYL
  • 123,309 MILES
The horn in my 97 contour is not working. The 2 horns are fine I tested them and the fuse is fine. How do I remove the steering wheel cover to replace the horn switch
Wednesday, May 14th, 2008 AT 9:02 AM
HOUSKER
  • 7 POSTS
There are 4 screws behind the steering wheel towards the dash. I believe they are star screws. Take those out and the cover should come off. Be carefull tho when working around the air bag module.
Monday, May 19th, 2008 AT 7:40 PM
BILLHORTON777
Had the same problem on my '98 and discovered rust/corrosion on the horn bracket was preventing it from grounding. Horn worked fine when I tested it with 12 volts, then I cleaned the bracket before bolting it back up and the horn worked fine. So, make sure the mounting bracket is grounding properly to complete the circuit.
Saturday, October 6th, 2018 AT 12:23 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,416 POSTS
Great addition to this thread! Please feel free to help out whenever you are on the site :)
Cheers, Ken
Saturday, October 6th, 2018 AT 3:19 PM
