1996 Ford Contour Horn Stopped Working
TARTOP
  • 1996 FORD CONTOUR
  • 6 CYL
  • FWD
  • 16,000 MILES
Hello.
My Horn just stopped working, I checked fuse and horn relay both OK, horn works when I use the FOB to lock doors and it also works when I push the panic button on the FOB. Any suggestions would be greatly apreciated.
Thank You.
Wednesday, July 14th, 2010 AT 2:25 PM
  • 108,450 POSTS
Is there any noise that comes from it when you use it? Has the Air Bag light come on?
Tuesday, August 10th, 2010 AT 1:29 AM
TARTOP
Thank you for the reply.
No noise at all, and airbag light does not come on.
Thank You.
Tuesday, August 10th, 2010 AT 6:03 AM
  • 108,450 POSTS
My guess is the "clock spring" in the steering wheel is bad. Usually, the air bag light will come on with it.
Tuesday, August 10th, 2010 AT 10:57 PM
TARTOP
OK than you for your suggestions/help.
-Hank
Wednesday, August 11th, 2010 AT 6:07 AM
  • 108,450 POSTS
Hank,
Let me know if it takes care of the problem.
Wednesday, August 11th, 2010 AT 9:14 PM
