Timing belt timing marks
STRAIGHT IN
  • 1996 MAZDA 626
  • 29,500 MILES
Is the timing belt connected to the water pump?
Friday, August 2nd, 2019 AT 4:59 PM (Merged)
CARADIODOC
  • 33,751 POSTS
There's six engines listed for this model and year. None show the water pump being driven by the timing belt.
MS-EGO
  • 1997 MAZDA 626
With a 16vavle?
What about any diagrams?
CATCH_15
  • 250 POSTS
There should be a notch on each camshaft sprocket. Those need to be facing each other and lined up with the top of the cylinder head when the #1 is at top dead center on compression. Next, there is a notch in the crank pulley that needs to be pointing at the marks on the timing cover. If your engine has a distributor, line the rotor pin up with the #1 point on the cap.
COUNTRYBOY 1982
  • 1995 MAZDA 626
  • 6 CYL
  • FWD
  • 248,769 MILES
Need to know what the timing marks are for a 1995 mazda 626 2.5 v6
  • 108,262 POSTS
Go to the timing belt diagrams site listed on this page. Put in the necessary car info and it will provide you with the info.
