2002 Dodge Ram
KERRY75
  • 2002 DODGE RAM
  • V8
  • 4WD
  • 86,200 MILES
Im getting a misfire code on cylinder 2 and am burning coolant was told by my brother-in-law that it could b a intake gasket leak or a head gasket leak. Which should I replace first?
Friday, August 13th, 2010 AT 10:58 AM
  • 108,530 POSTS
Chances are it is the head gasket. I recommend that first because if it is the problem, you will have to get all new intake gaskets a second time if you only replace the intake. You could check compression to see if that cylender is low or intake vacuum to see if it is low.
Friday, August 13th, 2010 AT 5:51 PM
