Engine Mechanical problem
2002 Dodge Ram V8 Two Wheel Drive Automatic
I cannot get my timing chains to line up before disassembly. Engine runs.
Tuesday, August 17th, 2010 AT 6:31 PM
WRENCHTECH
MECHANIC
What engine do you have?
What are you doing to it?
SPONSORED LINKS
Tuesday, August 17th, 2010 AT 6:53 PM
GINGINTN
MEMBER
Working on a 4.7 timing chains. I can't get the old chains timing marks to line up before disassembly. The truck was running good before-hand. It is not out of time. It was having head gasket problems. Secondary chains were a little loose, was going to change them while I had it apart. I rotated the motor until I got worn out. Thanks for your help!
Saturday, August 21st, 2010 AT 12:36 PM
WRENCHTECH
MECHANIC
I don't know what to tell you except you may not be lining them up correctly.
