94 Intrepid - Trouble Starting
RDSBEAR
  • 1994 DODGE INTREPID
94 Dodge Intrepid, 164,000 miles, 3.3L. When you turn the key you just get a click. This happens intermittently. We have also noticed that the lights on the climate control module do not turn on. We replaced the camshaft position sensor and the crankshaft position sensor. We also had the starter checked and replaced a wire on the starter. What other components should we check?
Tuesday, November 6th, 2007 AT 1:57 PM
MERLIN2021
  • 17,251 POSTS
The barrery is OK? Check the negative battery cable were it attaches to the block, if you have a volt meter, put the pos end on the neg batt terminal and the neg end at the end of the cable at the block, Should be not greater than 1/2 volt voltage drop when cranking from battery volts.
Tuesday, November 6th, 2007 AT 2:56 PM
RDSBEAR
The battery is OK. Any other suggestions?
Tuesday, November 6th, 2007 AT 4:02 PM
MERLIN2021
  • 17,251 POSTS
That test was for the battery cable.
Tuesday, November 6th, 2007 AT 4:59 PM
RDSBEAR
Should have stated that more clearly. Battery cable and battery tested OK. Any other suggestions?
Tuesday, November 6th, 2007 AT 5:36 PM
