Diesel put in fuel tank
CODYKELLER1
  • 1997 FORD F-150
  • 148,000 MILES
Accidentally put less than a gallon of diesel in my truck. I drove on it all the way home before I realized my mistake, so I put unleaded fuel in after I shut it off. Now it wont start. What do I do?
Wednesday, June 1st, 2016 AT 9:48 PM
HMAC300
  • 48,600 POSTS
That really should not hurt it to much, but about the only thing you can do is have a mechanic put injector cleaner through it to try to get it start. you might try using choke cleaner to fire it then check fuel pressure with a gauge auto parts rent it.
Thursday, June 2nd, 2016 AT 7:20 AM
CODYKELLER1
Can you buy injector cleaner? I don't have a lot of money so I am trying to do this myself as much as I can.
Thursday, June 2nd, 2016 AT 7:29 AM
HMAC300
  • 48,600 POSTS
You can get it, but it is not really that good and i am just taking a guess as to why it wont start. check to see if you have pressure like sent article. if you only put a half gallon in and then like 5-6 of gas it should not hurt any. check your fuses etc. also follow this link on what happens when it wont start. I am assuming there is no check engine light on as well you might try resetting security system as well if no owners manual look online for your vehicle on how to do it.
Thursday, June 2nd, 2016 AT 7:50 AM
CODYKELLER1
Now it wont even turn over.
Thursday, June 2nd, 2016 AT 12:04 PM
HMAC300
  • 48,600 POSTS
Probably your battery is low recharge it and try resetting security system if no owners manual look online for your vehicle on how to do it.
Thursday, June 2nd, 2016 AT 1:04 PM
