1992 Chevy Camaro
QUINCY_THOMAS
  • 1992 CHEVROLET CAMARO
  • 6 CYL
  • 116,000 MILES
3.1 v-6 92 camaro. Getting good spark from the coil to the distributor. From the distributor to the spark plugs has weak or no spark. Replaced the cap rotor and ignition mod. What else could it be?
Sunday, August 1st, 2010 AT 11:19 PM
HMAC300
  • 48,600 POSTS
It could be a weak coil or anything actually. Check your fuel pressure though as you may be low on pressure an dyour injectors aren't working properly. If you go to the tune up site on here it goes through a step by step on how to check your ignition system, rather than explain on here. It covers all systems so get to yours first you should be able recognize yours.
Monday, August 2nd, 2010 AT 6:01 PM
QUINCY_THOMAS
The coil is brand new and its getting plenty of spark from it. Just the spark plug wires. Arent getting any spark threw them. And there is plenty of fuel pressure.
Tuesday, August 3rd, 2010 AT 1:17 AM
HMAC300
  • 48,600 POSTS
It has to be sometign in the cap or the rotor itself. It could be shorting out on the distributor shaft. Or your coil wire may be bad as well. EVen though you show a lot of spark at the cap through the wire it may be in a spot where it hits. Try sanding the contacts inside the distributor cap as they may have some lacquer or something on them not letting the spark go through it. Check the rotor and dist cap for cracks as well as that may be another thing that is causing this.
Tuesday, August 3rd, 2010 AT 10:39 AM
