1985 Chevy Camaro No spark to coil or dist. Cap
STONECLD303
  • 1985 CHEVROLET CAMARO
Engine Mechanical problem
1985 Sunrunner Boat V8
Ok my problem is actually with a boat engine it is a 1985 Sunrunner that has a small block chevy engine. The specific's are as follows. Merch crusier 260 with a thunderbolt electronic ignition. My problem is as follows the other day I went out to do a tune up on my boat I replaced the following parts Cap, Rotor, Plug wires. I did not do the plugs because I could not get to them and did not want to take even more things apart. So I did that and tryed to start the engine up and all I got was cranking. So I thought ok maybe I got something crossed with the fireing order, nope thats fine. So then I thought maybe the coil went out so I went and bought a new one. Installed it and tried to start the engine again and got the same responce just cranking. I looked over all the electrical wires in the engine capartment and they all look just fine. I then went down and bought a spark tester hocked it up to the coil and cranked the engine and no spark, hooked the old coil up and tried again with same results. I checked the plug wires from each plug and still got the same results no spark. I would also like to add that all the replacement parts were ordered online for this engine with this ignition system. So now that it has my head spinning I am seeking help online. I hope I have given enough info on my problem and the things that I have tried. Any help in this matter would really be nice at this point. Thank you
Saturday, December 5th, 2009 AT 6:43 PM
ERNEST CLARK
  • 1,730 POSTS
If you're sure that you didn't make a mistake in the wiring, then I'd say the "Ignition Control Module" is faulty, or you accidentally fried it.
But instead of replacing parts and hoping to hit the jack-pot, disassemble the ignition components again, then take them to your local parts store and ask them to check each one until you eliminate the faulty part.
Thursday, December 31st, 2009 AT 2:27 PM
