Heres the pic. If you decide to take this route and not drop the tank, be very careful when cutting. I used tin snips to do mine. Afterwards be sure to seal it up really good or youll get that fuel smell inside the car. Silicone caulk works good. If you decide to drop the tank, it should take about 3-4 hours. Thats what I average by myself but then again Ive done tons of them. I prefer the cutting method. Hope this helps ya if you need to get to the fuel pump. Good luck. :)
Wednesday, July 1st, 2009 AT 10:31 AM
